Thank you. I just want to finish the assembly because there are a lot of other things I need to be working on. The test and tuning phase can take a while. It wouldn't surprise me if I ended up changing the pipe, carbs, and ignition before it's over. My black and white X4 hit 61 so I MUST blow past that to be where I wanted to be from all this.
Minne thanks for the billet filter thought. My concern is that a bypass would drop the water pressure. They have really small restriction jets(#65 on stinger and wb) to feed. I went with a 75 and a 80 for starters but still......I'm just thinking if I give the water another place to go it's not gonna push through those little jets. That leaves no good place for the case cooler to tie in. With a #115 holding the water back it's just not gonna flow under there too well.
