Thanks guys! Yes I think I'm going to loose blue as a color. I have the rest of the black rails from the 99GSX donor to install. Those 96 blue corners are the only ones that covered the shorter rails(it was originally a 96). The gauge insert is stepped down in size and a tight fit so it would be hard to reverse.
Today I put the first pump and nozzle combo back on to try and bring the revs down and the top speed up. This one has the water supply fitting in the pump(not the pump support like normal GSX's) so I have to silicone it in each time. I hope to try the results right before dark after giving it a little dry time.
I also hooked up a couple factory scuppers. They don't weigh much and might as well be in there trying to pump water out as I'm going along. Another thing that helps a lot but is not that sexy is rubber bumper placement. I like to take the rubber that comes on a water box support and cut it into smaller pieces. Then weatherstrip adhesive will hold them in a spot that stops a rattle.
 Thanks Oscar for the plug offer. I want to get a fuel gauge for that hole though. The trim up button on my left thumb quickly changes the egt gauge's screen as planned. If I'm watching revs and my temp on either cylinder hits my preset limit then it will automatically change to that cylinder's screen as well as lighting a red led.
