Hey all,
Last weekend I started getting my 1994 GTS ready for the summer and upon visual inspection, noted that I needed to replace the wear ring. Following the manual's instructions, I removed all the bolts and ball joints, and the assembly seems locked to the back of the transom. There looks to be a bead of glue coming from the way back of the assembly but I am not sure. From what it seems, I should be able to slide the assembly out, giving me easy access to the wear ring so I can replace it and add in a new neoprene seal. Also to note, I removed the nose cone from the jet drive, drained the oil (which was black and very fragrant), and did not loosen the square connecting bolt to the drive shaft. I don't know if I am missing a step here, because it seemed from other posts that the shaft did not have to be disconnected from the fly-wheel. Also, I would think that the only course to take would to take an angled pry-bar and gently tap my way through the glue, but I really don't want to ruin the fiberglass back there.Any help would be great here as this seemingly painless repair had become a long chore.
Thanks!
Thanks!
