Just got the boat out from storage after two years and replaced battery and plugs. Port engine was smoking badly when I started it. Opened the hatch and noticed that a head bolt was completely missing and water was pouring out because I still had the flush hose attached and running. I'm guessing this is probably letting a little water into the cylinder causing the smoke? Otherwise it runs fine. What else could it be? It seems to be a white steamy smoke.
Secondly, I have had cavitation problems in the past and have searched many threads here. I'm about to check the carbon ring, impeller and wear ring. I'm not sure how long the head bolt has been missing or even how it seemed to have vanished, but, would this be a cause of cavitation and is it normal for the entire bolt to just loosen and then pop out? Its approximately three inches long.
Also my vinyl seats are completely worn out on the tops. Does anyone have suggestions or experience replacing the vinyl. It does not appear to be very easy to get the cushions off.
Any help would be appreciated. Thanks
J
J
