Thought I should tell you.For metal to protect itself,it rusts,Thats why underwater they still find old boats.Air is what accelerates the corrosion.Galvanising puts a metal coating on whatever you want.To protect itself,you see oxidisation.The white stuff you get on gal.OR rust on metal.Apples oxidise.Cut them and they go brown.So do white grapes.Its a combination of air humidity and chemicals in the air.Moisture on whatever you have,helps this process.eg fruit.and acids
Galv.will get a very thin coat of white film and dipping it in and out of the water(boat trailer) will build up this oxide.
If your trailer has been painted and not properly prepared to stop the oxidisation,there is a very thin layer of powder between the trailer and the paint.
This is why the paint on your trailer will fly off
(it's also good fun)
