I have read another post similar to my issue, but can't seem to find it right now.
Two rides ago my wifes ski got an ENGINE light. So I had her turn it off, wait about 30 seconds, and restart it. But it was dead, so no restart. The display had lights and I think it would beep, but would not even try to start, (no cranking).
So I towed her in and got a new sealed battery for the simple fact it was four seasons old. Went out today and it will start start most times, but it is in LIMP mode and maxes out at 32mph. At first we had the IBR functions, then lost them. Ski runs fine when running as far as engine noise and performance other than it is in LIMP MODE. We turned it off and talked for a bit, it would not start/crank.
The entire day it displayed IBR MODULE ERROR and would produce about a 2 second tone and the engine light has been on. Only stored code is B2214 which is "VTS UP/DOWN switches
disconnected fault". There were other codes as well, but I THINK they had to do with either a low voltage issue and or connected to the existing issue.
I have the battery on trickle charge (2 amps) and will start it later on and see what the voltage is at the battery. I just want to make sure it is charging.
So,,, anyone have a clue to what the issue is? I'm not sold it is an IBR MODULE, but it certainly could be. I pulled the POWER PLUG and the IBR MODULE PLUG from the IBR unit and I do not see any corrosion or water within the plug. To be sure, I poured 97% alcohol on the plugs then hit them with a heat guy to evaporate the alcohol. Put it all back together and still same issue.
In a nut shell, even if it does start, it almost never gets the two beeps. Just keep hitting the start button and it seems to start 6 or 10 pushes later. It is still in LIMP MODE and still displays IBR MODULE ERROR. Also, no matter if the lanyard is on or not, it keeps scrolling READING KEY. Putting the key on changes nothing, still says READING KEY.
Any advice is appreciated.
