Hi All, new member here but I've been relying on all the good advise on here for a while. Unfortunately I have a problem that I can't find an answer for.
Long story short(ish), my kid capsized our 11 gti se which got the screen wet. A new screen worked but the key wouldn't turn off. A new key post didn't fix it and I ended up having to get a new ecu. No codes before the ecu and now I get code C0073 with a solid engine icon. The ecu software was updated and everything runs fine, including the ibr overdrive, but the reverse and neutral won't work. It has a brand new battery with tight connections. It feels a bit slower than before but it's taken almost a year to get to this point so I'm not sure I remember how it ran before. I'm losing faith and can't see how buying a new ibr is the answer if the overdrive works. Any help would be hugely appreciated. I'm pulling my hair out!
