Fuel filter replacement
500whp335i
Hey guys, that black box is just a fuel pump right? The only two fuel filters I need to change are the canister one before that black box and the water/ fuel separator on the other side of the motor right?
Yep... the box is an electric lift pump. It turns on while you crank the engine.
Once running... there is a vac powered pump.
Unless someone put another filter in... yes... you basically have 2 filters. The metal one under that pump, and the larger spin on. There is also a strainer on the high pressure pump, in the vapor tank... but that's not a normal replacement part.
Thank you once again Tony! You wouldn't happen to have a part # for that metal one? Ended up selling the boat and need to get it ready for the new owner! On to a Chaparral!!
