vert
1993 Seadoo GTS. The ski has been running great this season after purchasing last fall. All routine maintenance up to date. Carburator rebuilt with Mikuni parts. Black fuel lines. Decided to clean the fuel filter/water separator today. Unscrewed the canister and cleaned it all. Wasn't too dirty anyway. Verified the o-ring was OK and screwed it back on tight. Went back to start and it cranks but won't catch or start at all.
- Compression seems to be good at around 135 on both cylinders.
- Spark plugs are new, properly gapped and firing. Added about a teaspoon of premix in each cylinder but it still just cranks and won't start. Tried adding the premix directly into the carb/throttle body with the air filter off. Same result.
- Disconnected the fuel line at the (single) carb. Gas seems to be flowing when cranking. Switching to reserve it flows real fast.
- Took the fuel filter off a couple of times. Each time it's full with fuel. Tightened securely.
- Tried different spark plugs. Same result.
- Took the carb off and inspected. Clean, no issues.
- With the air filter off I can see that gas is flowing/mixing with the air in the carb. With choke on and cranking gas mixture is flying out of the throttle body.
- Engine WILL START for less than a second if I take the plugs out, crank the engine, put the plugs back in and crank again. After that split second start, it will just continue to crank.
Like I said, it was running great before I decided to clean the fuel filter. I started it right before doing this maintenance and it fired right up.
Any ideas? All help is appreciated.
Edit: additional testing in bold.
