lilngineer
I managed to get my pump fully disassembled for overhaul this weekend.
I am curious about the through-hull fitting. My fitting is only plastic and has an inside diameter quite a bit larger than the shaft.
Is this normal?
In the service manual, there is mention of a knurled aluminum insert to be glued in the fitting from the engine bay side.
Should my boat have one and it is missing? Does this close the gap between the ID of the fitting and the OD of the shaft?
Thanks,
Jason
Is this normal?
Thanks,
Jason
