hellz_wings
Hey all,
Just rebuilding my pumps on my 98 speedster with twin 787's but I am about to torque it all down but before I do, I wanted to ask if anyone had any issues using the WSM rebuild kits for the pump, more specifically, the thrust washer not fitting in the center bore (when putting it in like the manual states, putting thrust washer in the hole, then thrust bearing then putting impeller shaft through the whole assembly using that special tool to keep it straight I guess). I re-used my old washers since these WSM ones did NOT fit in there (I can see this getting totally messed up if someone did not pay attention to this and just torq'd it down with it being not seated in the center bore).
I suppose this is common as on some vids online people say to re-use your existing thrust washer and not the aftermarket one?
