PolarCelsius
95 XP does not crank with start button, dash turns on and then turns off
It DOES crank by shorting solenoid, and also DOES crank on its own (only for a second) when key is attached, and only when grounding the MPEM to the stator for the first time, otherwise the stator connector must be disconnected and reconnected to repeat the crank.
Gas light remains on, and temp light flashes twice when attaching the key
VTS system has been disconnected from MPEM by disconnecting the red wire and ground coming from the VTS module, including it's fuse that goes to the solenoid
My beeper does not work in general sorry no beep codes to share
Please watch this video demonstrating this unique problem-
