P paul korp New Member May 25, 2010 #1 put ski in water with new battery get one or two passes with it. come in to change riders and wont start any ideas.
P paul korp New Member May 25, 2010 #3 reply to 1996 spi starting issue have good spark. what connection should i look at. battery cables are tight. spark plug wires tight. or am i missing something
scooper77515 freebie fixer Premium Member May 25, 2010 #4 Ground cables. Clean the DESS. Does it even beep when you try to start it?
Dr Honda Well-Known Member May 25, 2010 #5 Were the carbs rebuilt recently??? If they were... you have bad diaphragms, and your engine is flooding when you turn it off. The import diaphragms allow the needle to leak.
P paul korp New Member May 27, 2010 #6 reply no the carbs have not been rebuilt. ski will start and run after being on battery charger but only for one pass.
scooper77515 freebie fixer Premium Member May 27, 2010 #7 So you are suggesting that the battery is dying while you run it? If so check the charging system.
Bills86e Premium Member Premium Member May 27, 2010 #8 Won't restart scooper77515 said: Ground cables. Clean the DESS. Does it even beep when you try to start it? Click to expand... 1996 SPI's don't have dess, its a 587 motor. Remove starter and put new brushes in it. Bills86e
scooper77515 freebie fixer Premium Member May 27, 2010 #9 Still sounds like he is running off the battery, and after one ride, it has sucked the battery dry, like it isn't charging. This could indicate a charging problem, or still (as mentioned earlier) a bad connection between charging system and battery.
P paul korp New Member Jun 16, 2010 #10 1996 spi charging problem still working on it. got new rectifer going to replace it over weekend. had it on battery charger that checks the alternator said it was bad. also said had bad cell went thru three battery lastsummer same problem. any help would be great
