orbit398
So I bought this one along with an XP, both have issues but was a cheap purchase. This HX didn't spin as I tried to rotate it via the fly wheel and it would budge. removed head and all looks ok. Took off starter and the crank rotates. Odd..... Tested starter on bench and it works just fine. So maybe is was just jammed? weird. But, where the starter bolts up to motor, the hole is full of premix oil. I can see the flywheel/teeth in oil. Don't think there should be any oil in there, correct?
wonder how the oil gets into there.....see pic, flywheel teeth disappear into the oil
thanks for any advice
