Woodsy15
Hey, getting near the end of season so don't know if I will get out to test this more or not before spring. The Speedo on my 05 Challenger is off reporting -12 mph (boat going 43 mph on GPS, speedo reads 28-29)
Found a long lost Technical bulletin on another forum that shows on the back of the Speedo you can remove a plug and use a 2mm allen key to turn the speedo bias up or down.
Do you think thats the problem/solution? or could it have anything to do with the speed sensor paddle wheel on the back (pic) ? It spins freely and has a bit of play left to right (not sure if thats normal or not)
