MaxsvenssonSWE
Hi! While i was riding my pwc couple of weeks ago i got the warning message "oil". I stopped and found out that i got oil in the hull. Back home i plugged in the water, starter and looked for the leak. Found out that a lot of oil were coming from the oil filter Box. I removed the cap but the o-ring looked OK. My conclusion was that i got too high oil pressure. I looked around for some solutions on the forum and decided that the first thing to do was to change the oil pressure regulator. I lifted the engine and dismounted the regulator, found some scratches on the piston part so i changed the regulator parts + oil filter and o-ring. Mounted back everything and started up and still got the leak.
Do you guys have any ideas? Could it be a problem with the TOPS valve that causes the leak?
Thankful for all kind of Answers and ideas that can help me! // max
Sea doo GTX 2002 limited edition 155 HP (400 hours)
