CReynoldsMIZ
Did I miss something? Why would he need to remove the whole engine? Why cant he just remove the R/V cover and drill it?
You should really be using a torque wrench, takes the guess work out of it. I try and use it wherever I can. That way you don't have to worry about under or overtightening and damaging the threads.
Yup, I'm not sure there is anything on this engine that uses red loctite
Just get an inch lbs wrench. They are not that expensive. Good to have especially if you have more jet ski projects to work on.
really ? y'all don't use red ? case, cyl, head, mag cover ?
