OldieButBaddy
Hello everyone, and thanks admins for the quick turnaround on approving my login. I much prefer forums to fb pages for tech help, so hoping I came to the right place!
I recently picked up (for next to nothing) a 1992 XP 587. I perhaps should have spent more
Supposedly it ran last summer, and I did see a video of it on the water, for whatever that is worth. Few problems now I'm hoping to get some help with. I have decades of DIY experience on 4 stroke boat/car engines, but 2 strokes are entirely new to me, so please be patient with my lack of knowledge.
When I brought the ski home, it started right up, and ran until I killed it a couple minutes later. At the time it was leaking water like crazy, as three of the studs for the exhaust pipe (to manifold) were broken off. I have that mostly straightened out now - but I can't get it to start / stay running. Two problems I'm noticing. When I have my finger on the starter button, and while the starter is spinning, it sounds like it's running. But as soon as I take my finger off the starter button, it seems like it loses spark, and dies. On a four-stroke motor with these symptoms, I would test the positive terminal on the coil - and expect it to be hot when the starter cranks, and dead when the ignition returns to the on position - due to a bad ignition switch, wiring, resistor, etc. But in my new world, I haven't a clue how to diagnose. Suggestions?
I also think I need a new starter - sometimes it cranks fine, for as long as I'm on the button. But just as often, the starter turns the engine a few revolutions, then disengages itself and just spins the starter motor. I suppose I need to replace my starter? Any recommended sources for a quality replacement? Doesn't look like the easiest job getting the starter out, and then in, so hoping to only do it once.
trying to think of any other info that would be helpful. Compression seems good, both at 145-148. Fuel lines look new. I drained as much as I could from the gas tank and filled with new fuel. It's set up for premix ): but let's not discuss that! And the choke cable is not connected to anything.
thanks
thanks
