:chillpill:...its alright, bud. Locate the oil feed line to the motor/pump assy, and remove that line, but empty the oil tank first. Then with line disconnected, allow it to drain, then re-install, fill oil tank up, and if anything, while idling, reach down to the pump arm, and hold it all the way open, allowing the oil to dump into motor/purge the system with the new oil.:cheers:
