HELP! wife put gas in the oil res.!
fazbac65
My wife took our 2001 sea doo RX to the gas station and accidentally put the gas in the oil reservoir! About 2-3 gallons she thinks. The ski was never started. Aside from siphoning out the gas... what else can I do? I am a novice so could someone walk me through? Thank you
:chillpill:...its alright, bud. Locate the oil feed line to the motor/pump assy, and remove that line, but empty the oil tank first. Then with line disconnected, allow it to drain, then re-install, fill oil tank up, and if anything, while idling, reach down to the pump arm, and hold it all the way open, allowing the oil to dump into motor/purge the system with the new oil.:cheers:
