Hopefully someone can help me out..... I'm having a bit of a situation with my 2001 GTX DI. So here goes......
At first, it would beep and was starting for about ten seconds and blowing the 15amp fuse in the MPEM with a bit of smoke coming from the injector. Everyone told me it was the rectifier. So I put in a rectifier as this is common to go on these and I put in a new battery.
Now, when I put in either of my three landyards I get the gauge/dash display and I hear the fuel pump come on, but I get no beeps and no cranking. It does not beep after hitting the start/stop button five times either. The battery reads 12.51 volts and the solenoid reads 12.51 volts. It does crank when I jump the solenoid.
Some say it's the solenoid and others say it's the post. This is a clean/spotless, lubed, non-corrosive ski with 75 hours. Does anyone have any advice???? Greatly appreciate it.
