sail_two_ski
Hi all i'm at my witz end and and could use some help, 2000 GTX 951 carb No spark confirmed with spark tester, Had the mpem tested at westside powersports and even found same machine put this computer in it and started. At the ebox power to solenoid all fuses check out, All wires check out from ebox to computer. Good reading from stator/ rectifier. All pin locations check out. Replaced pick up trigger.
No power being sent to the coils at the back down through the white wire, So the computer isn't telling it to send the signal there. Stator has power, Flywheel appears correct as magnets are on the outside.
Pick coil?
anything else? I plan on pulling the engine out to see if there's something I missed.
Thanks for the help.
Pick coil?
