brobertov8
http://youtu.be/mV9TRlL7ldM
Hello All,
My GTX 04 SC was running perfect, actually very good to be true.
Went to a big lake yesterday, 220Miles away from home.
After 40minutes riding, I got buzzer and warning light... Almost instantly the engine starts to fail. it was not LIMP mode for sure. It did sounds like more a lost spark or something like that.
On the video link above you can see how the ski went back to the dock. It took forever to go back home, at 3000rpm...
The strange is below 3000rpm I got warning light and buzzer as you can see... and the error code P1607 (MPEM FAIL)....
And if I try go above 4000rpm, the engine will do but failing a lot... looks like 2 cylinder working only... and it will be a massive cavitation.
My main question is:
Did I get TWO DIFFERENT issues at the same time??? Like MPEM Failure AND a wear ring problem??
Or maybe my MPEM goes away and then I got cavitation due a not normal engine running???
Could you guys please whatch the video and give me some light?
PS: On the CANDOO I god the same P1607 error... MPEM failure..... Just clear the codes today, start the ski out of the water and almost instantly I got the same error again... P1607.
Thank You!
Hello All,
Thank You!
