2strokenewbie
I have a 1996 Seadoo GTX 787. I opened the mag cover today and found a broken trigger coil (wire broke at solder location), and broken trigger coil bracket. There is also a lot of oil inside the magneto housing. I also found several lose metal pieces, including small pieces of spring, and magnetic metal chunks. I have no idea if these pieces are all from the trigger coil bracket. The link has pics from the mag housing.
https://www.dropbox.com/sh/ruvzgsyy0tf7d0j/AABUBKjgtp9hkxkCvcRTTqpMa?dl=0
I am thinking that I need a new trigger coil and bracket, and possibly an oil seal and gasket that goes between the magneto housing and engine.
Any advice is much appreciated!
