boogidyboo
So a while back i sucked up a tow rope towing a Wake Board. After we removed the rope I drove it around and everything worked fine.
A week after that, I was driving it and it was only running on one cylinder.
I found a wire in the electrical box that was broke, so I re attached it and everything was running really good except it would only do about 40-45 MPH in the water versus the 50-55 I use to get.
Than the following week, I took it out again and it was running fine till i started doing 360s and than it would only Rev up but not move very fast Maybe 10 MPH at that most for about 2 min. Than all of a sudden she took off again to the full 40 MPH.
I put it on the trailer and went home, and it had a bunch of water in the hull. also i noticed a hose clamp that goes around the drive shaft was off. I found this hose clamp to hold that rubber boot on.
Is that rubber boot suppose to attach to that slide bearing?
would that cause it to run goofy?
Im so confused?
Do i have a bent drive shaft from the rope?
Im so confused?
