shanebell618
Going through some pre-season maintenance and had a couple of quick questions:
1. Greasing the "drive shaft" (rear of the ski under latch cover). I understand this is a zerk fitting.
Could anyone point me to a cheap grease gun kit that would have the right size fitting I will need?
Or just tell me which size fitting I should look for at harbor freight, etc.
Also, are there any other fittings on this ski that I will need to grease?
2. I am going to be replacing the inline oil filter.
I have read on the forums about clamping the lines above/below the filter, changing filter, letting oil run through new filter, and re-connecting.
Is this a safe method to avoid air in the lines? If not, how would I proceed without getting any air bubbles. (I would prefer to not drain the whole system if possible.)
Thanks
Also, a big thank you to mikidymac for his "Seadoo Carb Rebuild Thread". As a first timer, I was able to successfully do a complete rebuild on my carbs and everything went great.
Thanks
