Oil in cylinder - aka Leaking crankshaft seal on 787
Doug Overkill
Hello forum,
I know this topic has been covered a lot and I have spent the week reading a bunch of the threads and still have a couple questions. Most of my questions are about peoples actual results. The issue is a very common 787 one in that the seal on the crankshaft leaks 2-stroke oil from the rotary valve gear into the bottom of the cylinder (Mag side in my case). If I run the boat everyday it is not enough of a leak to be an issue, just a little extra smoke on startup. Clearly the best answer is run the boat everyday! Unfortunately I have to go to work and live and have responsibilities and so the boat sits for several days or a couple weeks at a time. When this happens there can be enough oil in the cylinder to hydrolock the motor. As anyone who has this problem knows, remove plugs and crank until it stops spitting all over the engine bay. Remember to pause every so often so you don't cook the starter! Once most of the oil is gone, replace plugs and start her up. A bit of mosquito control later (smoking) and she runs great.
I have decided this fall/winter I would 'fix' this. So there are 4 solutions talked about on several different threads including this one:
787 crank seal leak in which @markg612 lays out these options:
1. Do it right - Replace or rebuild crankshaft and add 518 sealing the new seals in place - most expense option!
2. Split case and seal existing seals with Loctite 518 - cheapest with a bunch of labor
3. Seperate RV oil supply & vent from reservoir- replace oil with thicker lubricant so that it won't flow thru seal
3a. new lube is 80/90 gear oil or something thick
3b. oil lines get a Zerk fitting and pump this RV gear area full of grease. Such as XPS 293550010 (for driveshaft couplings)
4. Add ball valve in the supply line shut off when not in use. Remember to turn on when is!
I like option 2 the best, but it is a BUNCH of work right before snowmobile season.
#4 seems easy but I expect that a lot of oil still ends up on the wrong side of the seal as you have stopped the large supply only and whatever is in the area can still leak thru.
For those of you who have done any of these. Please post back with your results. Would you do anything different? Would you recommend this to others? For those who did #3, what lubricants did you use? Did you have any leakage that resulted in smoke or other issues? Did it survive for very long and is it still running that way. Did anyone use the zerk fitting method?
My motor is strong and has 150,155psi compression, checked today. I do not really want to replace a crankshaft on a good running motor. I also want to stop/slow the oil leak so I don't loose an hour or more on a Saturday morning pumping oil out of the cylinders cause it sat for a week.
Seeing as the motor has nearly as new compression, I would put a ball valve on it for now. If you ever have more serious engine issues that require pulling it, dig into it then. If it was me, I would tie the key on to the ball valve every time I was done for the day, for obvious reasons.
I keep seeing people say that and was hoping for someone who tried it and had real world results. Have either of you?
My issue with the plan is that the rotary valve gear area is full of oil. How does shutting off the large reservoir prevent the hydro-lock? Seems like the seal would still leak. I’m not having gallons of oil come out the plug hole. After sitting for 2 full weeks I got 4-6 ozs. I’m sure that much oil is in the area as well as in the lines below whatever valve is added.
Im not trying to be argumentative just hoping for some actual results.
Here is most of the oil that came out after sitting 2 weeks.
The oil tank is above the engine putting static head pressure on the engine oil cavity.
Over time this small amount of pressure pushes oil past the seals very slowly (2-weeks for you).
Installing a ball valve prevents the tank pressure from pushing oil past the seals until you can replace them with a reman crank.
Thanks Miki. I convinced myself, probably incorrectly, that the head pressure couldn’t be THAT much of a factor in the leaking... so I tore open a good running motor to look at the crank seals. I figured as I didn’t know any history on the motor I should at least look. It will get a new piston and rings as the cylinder looks (measures) good.
I’m not going to redo the crank at this time. My plan/hope is to yamabond the inner crank seals to the case and hope that stops or slows the oil. If that doesn’t work I’ll add a valve to reduce the head pressure from the tank.
Sealant on the outside of the seals will not do anything, it is the actual seal lip on the crank surface that leaks.
I am choosing #2 and in the middle of it. Something I did not expect was the o-ring on crank had a spot that was super thin....air leak. This is all new to me, so tearing this apart, buying special tools wasn't something I planned on, but feel it won't be my last engine to rebuild. Great video's online.
#3 & #4 were my first choices....and did, but this ski sat all last year because engine needed more care than I thought.
