Good point Lou, that long pole makes it an expensive item to ship. Do they rent them out as well?
I don't know, probably not, if they do you would probably have to pay for shipping both ways.
Lou
Well I'm glad I decided to pull the engine. The rear piston and cylinder are toast. I can see through the piston next to the exhaust port! I wish I could figure out how to upload pictures
I'm curious to know if this motor had NGK BR8ES plugs in it like it should've?
And that's why you always check compression before you biy
Its been a while, but I got a lot done today. I got the motor in and aligned, rebuilt the pump, and put a new wear ring in. The other day I cleaned the carbs, cleaned the fuel tank out , and replaced all the fuel lines.
I did manage to fire it up and run it for a second but I wanted to check with you guys before I run it. Is there anything special I need to do for a new motor? I really don't want to blow it up
I am sure others with more experience will chime in but I know the original Seadoo Manual for my 657X engine stated to put 30oz of the oil in the first tank of gas and to follow a break in schedule for the first 10 hours of not excessive WOT and also to vary the speeds.
