2002 Seadoo GTX 800 RFI crankcase oil question
elnook909
Hi,
I removed the drain plug to see if there was oil in there a small amount of black oil came out, my question is what oil type should this be changed with and how much needs to go in there through the filler plug/ Thanks for any input in advance.
Cheers
I believe it’s straight 30 weight oil, it’s a very small amount, maybe 15ml but you definitely need to check that because I’m going off memory. You will find the info in the manual and it’s available for free at seadoomanuals.net
