Hello,
I am wondering if anyone might have an assembly diagram or an actual photo Mikuni oil pump that was used on Seadoo GTX RFI's between 1998-2002. Showing the hardware used for the pump lever mechanism (locking washer, nut, return spring, if there's anything that might be between the spring and pump body ex. washer, spacer?). I have a pump in which all the pieces of the pump lever mechanism are disassembled but I might have all the necessary pump lever mechanism components, and would like to reassemble the pump. Any help would be greatly appreciated, Thank you
