I've installed the lever. Photo below. Carb is reinstalled. The ski now starts very easily. I have adjusted the idle out of the water to 3000 rpm (was very high after rebuild, 4600 rpm) and readjusted the oil lever to align marks. It runs very rough at idle. Removing spark plugs after idling briefly I found both very "wet". Should I adjust the low screw? The low screw was set to about 3/4 turn open before carb rebuild, current screw settings are 1 for low and 0 for high. When I removed the carb to rebuild it I found the carb was very clean, it actually did not look to be 20 years old and it looked like it had never been taken apart. The internal filter had just a little debris packed at the end of it. I did not replace the seat, needle, pop-off spring, or lever. I only replaced the internal filter, check valves, diaphragms, O-rings, and gaskets since the other parts looked fine. I don't know the history of the machine, the previous owner maintained it well, he may have had the carb replaced at some point. Some hoses were also obviously newer like the pulse hose to the carb. I've had the ski for 5 seasons. Other than being a little hard to cold start it always ran well until last summer. Last summer and this summer it would idle but stall when attempting to accelerate. Rebuilding the carb apparently solved the cold start problem but it still stalls when attempting to accelerate. I've read everything I can find on this forum related to the stalling. A couple of years ago I replaced the grey fuel lines and the vent check valves out of caution. I have just finished replacing the fuel selector valve based on what I have read. That may be part of the problem as I noticed a brief odor of gas around the valve each time I open and closed it. I also just tested the voltage at the battery when idling, I get only 12.6 to 12.7 volts at the battery posts when idling (same voltage reading as when not running). I have not tested the ski after replacing the selector. Based on the low voltage when idling do I have a bad rectifier? Or are there other checks I need to make first?
