This is my first time on the forum and first time messing with a jetski. I just bought two 97 gsx's both are bone stock and under 90 hrs. One is running one isn't. The non running one has been sitting since 08 and was hydrolocked with oil when I got it. It made a he'll of a mess when I turned it over with no plug! Most of it is coming from the front cylinder but there was a little in the rear. So I pulled the carbs and rotary valve off and oil is right up to the intake on the front cylinder. I'm assuming it's gotta be a crank seal or a bad seal between the case halves but was hoping for someone to back my assumption up. If that is the case what's the best way to get the engines out? I'm used to working on snowmobiles with a lot more room!
Thanks in advance
Thanks in advance
