project_seadoo
so ive canned my 93 gtx project, overal it was going to cost to much to fix
and picked up a 96 xp in much better condition got it for 800 on a galv trailer, over here in austraila this models still going for 3-4k!!!
anyway i brought mine off a bloke who had not used it in a few years and he was unsure if it would still run
so i brought it home cleaned out the carbs and she fired up but running a real high idle, but im not to worried about that at the moment as carbs will be going in for a rebuild
what my problem is in my starter sometime gets stuck on the "fly wheel" i guess youd call it in the engine and siezes the motor up, untill i remove the starter and reinstall it the it will crank fine till it gets stuck again?
this is the second starter its doing it to and it all so sounds like the starter is staying engaged whenn the motors running (loud buzzing/humming sound)
the first starter sharft and drive gear (whole piece coming out the front of the stater) completly snaped off!!
any ideas on what would be causeing this?
thank you
thank you
