J_loughman
I have a 1996 seadoo xp with the 787. Was towed in last ride due to a dead battery. Replaced the battery and the motor was locked up. Broke it free with channel locks on the drive shaft. Checked compression and both cylinders are 150. Engine cranks over good without the plugs in and no water comes out so don’t believe there is any water in the motor. When the plugs are in and trying to start it up it only cranks about a 1/4 turn and gets stuck. Replaced the starter as it was the original, thinking maybe it was too weak to crank the motor under compression, and still only turns a 1/4 crank and stops with the new starter. What could the issue be?
