Thanks man, 2 coats of paint and 3 clear. No wet sanding for buffing needed at this time
Awsome thanks that's how I did my spec 1 so I'll do the sameAbout an inch back from the surface that mates to the cylinders. If you have a stock mani around it's where those tabs are that get cut off.
Or, look in my 95xp800 thread. I hole punch tape so all i get is a small round circle.For your next resto on the rivet holes, once the duraglass just starts to harden you can cut off the excess with a razor blade and there is no sanding required. Makes it much faster.
Looking good.[emoji106]
sanded down my duraglass spots then put them in primer.
took me about 3.5 HR last night to sand the whole ski by hand with 320 and a block. Then I used scuff and clean with a Scotch-Brite pad to ensure I got everthing. On my holes I patched under the mats I just hit them with a DA to knock them down smooth since they will be covered and painted. Next step is to tape it up and let the paint fly.Nice work man you have me wanting to paint the top of my 2001 XP that I just pulled into the shop.
Nice touch on filling matt holes!View attachment 39130sanded down my duraglass spots then put them in primer.
View attachment 39131View attachment 39132View attachment 39133 took me about 3.5 HR last night to sand the whole ski by hand with 320 and a block. Then I used scuff and clean with a Scotch-Brite pad to ensure I got everthing. On my holes I patched under the mats I just hit them with a DA to knock them down smooth since they will be covered and painted. Next step is to tape it up and let the paint fly.
Thanks I'll look in to thatHey so heres a tip for you . I got this stuff from ebay called Oil Eaters concentrated degreaser. Sprayed down inside hull and ran through pressure washer at car wash ( ya really enviromentally Oregon friendly) wicked stuff. Inside hull turned out show room new. This stuff will eat decals so carefull.
when you removed the bumper trim you had to drill out the rivets so when you reinstall will you be attaching the same way? Does anyone know the size and length of the factory rivets? Do you apply any sealer on them as well? Always wondered about that.
yes you drill the rivets out. You can pick them up from menards. Let me look tonight. Dont use any sealer. On the corners and the front bumper i use bolts though.
You can get the exact factory rivets from McMaster carr.![]()
That is where I got mine. Probably have 50 left. Also a great source for the super tiny ones that hold the X4 plastic knee vents in front of the seat.
Not to de-rail the thread but could you post the part # on those as well? Very useful information!
