blkrvrbart
95 GTX has developed a random fuel delivery problem. After running fine for 20-30 seconds, it dies as though it is out of fuel. Sometimes if you let off the throttle quick enough it will regain enough fuel to keep running, but if you stay on the throttle it dies. Restarts and repeats performance problem. After reading some other threads, it looks like this is a common problem. I have the gray fuel lines, have ran it in reserve (that makes no difference), and have had rust particles in the sediment filter that I've cleaned out (rust particles? in a plastic fuel system-must be from somebody's fuel tank).
What fuel line should I replace the gray ones with? Do the carbs need a rebuild? What kind of fuel pump does this system use? I also have a 97 GTS - same gray fuel lines, not the same problems yet - but will this ski need the same repairs in the near future?
