Shop Discount Sea-Doo Parts
2015 gtx won’t go more than 42mph?!! Any help on this please!
Messages
1
Likes
0
Water Crafts
Gtx 155
#1
I have a 2015 gtx 155, with 30 hours on it and just started it up ready for summer, did new oil filter and oil before taking it out. Got it out on water and would only do 42 mph top speed?! If any one knows what the problem is, or have had this problem before, please fill me would be much appreciated thank you!
skiasylum
Messages
286
Likes
44
Location
MSP
Water Crafts
2011 Sea-Doo Wake Pro 215
#2
Love it, Southern Hemisphere member. Assuming it was faster before you changed oil and filter I would check your oil level. You probably overfilled the oil. Make sure you check the oil level correctly, it’s like a 4 step process. Service manual.
If the oil level is at the correct level I would then service the spark plugs, they should be changed every year.
Messages
11
Likes
2
Location
Massachusetts
Water Crafts
2012 RXT-260, My Doo
2012 GTX-155, Wifes
#5
Fuel Injectors. I posted here about my 2012 RXT 260 that came out of Winter storage and ran like crap, top speed 40-50 mph at best. After a second oil change and new plugs, it was 1 bad injector.
Messages
11
Likes
2
Location
Massachusetts
Water Crafts
2012 GTX-155, Wifes
#7
What I should have mentioned is that the repairs on mine were done at my local dealer. I know they used the proper BRP oil recommended for my SeaDoo. It had been in storage for >1 year through 2 winters.
mikidymac
Moderator
Staff member
Moderator
Messages
10,288
Likes
854
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
#8
What oil did you put in? Full synthetic will lower the oil pressure putting your engine into limp mode. Make sure you use the blend from sea Doo.
Just curious how full synthetic will lower the oil pressure? As long as it is the correct weight oil it doesn't matter if it is conventional or synthetic as far as oil pressure goes.
skiasylum
Messages
286
Likes
44
Location
MSP
Water Crafts
#9
Yes, only reason we don’t use full synthetic is the supercharger clutch washers doesn’t like it.
Messages
28
Likes
0
Location
Central Illinois
Water Crafts
04 GTX present
Past:
97 GTS
95 GTX
96 GTX
79 IMP
74 Ouachita
76 Mark Twain
#10
If his machine is the 155 like mine, we don’t have a supercharger. Is full synthetic okay for a NA 4tec? Just curious. Thanks
skiasylum
Messages
286
Likes
44
Location
MSP
Water Crafts
#11
Engine Oil
Recommended Engine Oil
Models with 155 Engine
Use XPS 4-STROKE SYNTH. BLEND OIL (SUMMER) (P/N 293 600 121).
If the recommended XPSTM engine oil is not available, use a 5W40 or 10W40 engine oil meeting the requirements for API service classification SM, SL or SJ. Always check the API service label certification on the oil container, it must contain at least one of the above standards.
Models with 215 and 260 Engines
NOTICE These engines have been developed and validated using the BRP XPS Synthetic blend oil. BRP recommends the use of its XPS Synthetic blend oil at all times. If the recommended XPS engine oil is not available, use a 10W40 mineral engine oil compatible with wet clutches. Damages caused by oil which is not suitable for the engine will not be covered by the BRP limited warranty.
The 155 Engine is much less restrictive: you can use any( If the recommended XPSTM engine oil is not available) 5W40 or 10W40 engine oil meeting the requirements for API service classification SM, SL or SJ. Always check the API service label certification on the oil container, it must contain at least one of the above standards.
SN and SN plus are the newer versions of SM. Just stay away from anything SA - SL
AircraftDoc
Messages
604
Likes
6
Location
Southern California, North of Los Angles
Water Crafts
2004 SeaDoo RXP. 2006 SeaDoo RXT
#14
Low pressure sensor are set at 28psi. Full synthetic has great shear strength. It is thinner, but not a problem, it just slips through the galleys easier. Slightly lower oil pressure. Ref ACEA
SPONSORED LINKS
Usergroup
