justridingalong
I submerged a stock 2002 Seadoo 155 Wake bike last month. Got it out of the lake right away, drained all water. Removed plugs and cycled all water out, once 100% dry added fogging and lube spray to cylinders thru spark plug hole and added new plugs. Then drained oil, filled with new oil added new oil filter and then started engine for 10 seconds, drained new oil again (slightly cloudy) and refilled with second new oil. New oil now looking great with no cloudy at all.
I let bike sit 1 month and now it only starts with ether.
I removed plugs and checked spark - 100% good. I removed fuel rod and check the 3 nozzles tips, all 3 are misting just fine. But bike will NOT run or start without a squirt of ether. And I am not getting that flooded smell and the plugs are not wet after attempted start. Bike was 100% full of fuel upon submerge and I have not changed fuel as it is still 100% full and there was zero indication of fuel on the water, but I did add 8oz Star Tron blue bottle to the full tank of fuel. Checked all fuses and all OK. Fuel pump fuse is same as starting motor fuse and starter motor is working so fuse must be OK.
Will not pop or start on its own, a squirt of ether and it screams to life for 3 seconds. I do have a garden hose attached and ready but have not turned on any water flow as I was waiting a few seconds of steady run.
Your ideas will be appreciated.
