With a 15/20 you are stepping down a minimal amount.
Not sure of your knowledge so please this is not meant as an insult.
The 15 is the diameter and the 20 is how far it travels if it were in a solid. For example, on a boat application if the prop was a 17/25, it would be 17 inches in diameter and it would travel 25 inches in one revolution.
This is important when considering a prop/impeller. Your OEM prop will travel 21 (I assume centimeter) in one revolutions and the one you are looking at will travel 20.
To understand the pulling power, think of a prop/impeller as a axle ratio. The lower the number the strong the pull. Which as you noted does come at a sacrifice of losing top end.
One HUGE difference between props and impellers is,,, the wear ring. So diameter is crucial with a ski as the close tolerance is much of makes our skis go. Unlike a boat, you can use whatever diameter you want as long as the prop does not hit anything when spinning.
In a prop world, generally speaking a larger prop is designed for slower boats that have the power to turn the prop and still keep the engine within good running specs.
In the case of the ski, you can only change the pitch...
By dropping only one-step in your pitch I am sure there will be a difference, just a matter of how much? Most times when people re-prop, they change both diameter and pitch. Again, with the skis we can't do that. Someone else will jump in here and offer their thoughts, but I think you will want to go one more step in order for you to FEEL a difference in you hole-shot or pulling force.
One thing to note is, in a marine application (aka boat), when you step one-inch with a prop it generally changes the RPMs by 200. It goes in reverse per-say, decrease pitch and it will increase RPMs.
Though I don't know this for a fact, I would assume this is CLOSE to true for our skis. If anything, I would guess with today's high tech engines it might be closer to a one-to-one ratio. But that just me guessing...
Clear as mud???
