Unleashednj
For starters Hi everyone as I'm new to posting on this forum but have gotten answer in the past by reading other posts.
I have a 2000 GTX ME which was doing nothing with my battery on it. so i put jumper cables to it and it was giving me the 1 beep meaning my lanyard was not programmed which i knew. SO i figured it was the battery and thus replaced. now even with the new battery it still does not beep and also no longer beeps with jumper cables on. I have also checked all fuses to make are they were not blown.
Could this be because an un-programed DESS Lanyard. that it would only do the beep once?(side note prior to getting new battery and doing the jump i did put the lanyard on hear the beep then remove it and put it on again and it still beeped. took the jumpers off to check for beeps and nothing then jumped again and had beeps)
should the DESS Post show power running to it, as a way of telling me everything is working and can be programmed?
I would hate to bring it back to the shop to program again and get charged $45 and nothing done.
I thank you in advance for any help given.
