Hi guys, don't know if someone can help me but I hope so. I have a 1999 SPX that I got from someone where it had been standing for years. I have tried to get it going again but its giving me issues. I changed all the fuel lines from the grey lines, put a new battery in it and got the carbs and starter motor rebuilt at a dealer. They say they tested it afterwards and it was working fine before they gave it back to me. When i used it, it worked for about 5 minutes before it started jerking or missing. If you hold throttle fully open it jerks and splutters or if you hold throttle constantly at half its not smooth and jerks. After it starts this missing or jerking then once you switch it off then it doesn't want to start again and you have to swing for a while before it starts and then it won't idle unless you hold accelerator open slightly. I took it back to the dealer and they stripped the carbs in front of me, they found one creased check/pump valve and said that was the issue. They changed that, I took it to test, exact same thing, worked for 5 minutes then started with the missing/jerking etc. Phoned the dealer and they said it might be the plugs, i changed the plugs, didn't fix it. Phoned them back and now they say its probably the ignition coil that's faulty and needs to be replaced. I have tested the coil with a multimeter and the readings were correct as per the manual. I told the dealer this and they said you can't accurately test the coil with a multimeter as spark can break down when under load. I took it to an auto electrician who also tested it on a machine and they said its working fine. Dealer says that the machine the auto electrician uses doesn't simulate under load conditions and that the coil could still be faulty. I feel like i'm constantly spending money on things they think it might be and its not solving anything so thought maybe someone on the forum might know what the problem could be. Could it be the ignition coil still? Would the pop off pressure on the carbs cause this issue as I never saw the dealer test the pop off pressures? What else could it be?
