i have a 1997 787 xp when i bought it there was a burnt piston.bought rebuild kit and put it back together.after running it for a while on a hose i took it to the lake it ran fine for about 15 min then it sounded like it would backfire through the carbs once in a while and would lose power.after idling around for a while and not opening it up it would take off and run good again for a while and then it would start doing it again after a while.i changed plugs a couple different times ,changed fuel filter, really cant seem to pinpoint the problem wondered if anyone else has had this problem or knows what it might be. any help would be greatly appreciated.
