1997SeadooGTI
I have a 1997 Seadoo GTI. It used to have trouble starting up. It would die when given gas. That is no longer the problem after I rebuilt the carburetor. I changed the fuel & oil filters, and starter solenoid before rebuilding the carb. After rebuilding the the carb, it started up right away. I drove it full throttle for about 15 minutes. I thought my problems were solved... but died when idling. When I tried to start it again, it won't start. It cranks but won't turn over even when I give it gas. I tried changing the low & high screws but it doesn't help. I noticed that the spark plugs are slightly wet with black idk what. The battery is charged. I would greatly appreciate any suggestions on what I should try. Thanks.
