1997 Sea-Doo SPX, This issue started after I removed the two carbs and cleaned them and replaced the gray hoses. Got everything hooked back up, but when I bolt the carbs back to the engine the throttle cable sticks. I've replaced the throttle cable since it was a little frayed. The carbs and cable seem to work fine while the carbs are not bolted to the engine, the valves open and close fine with the carb springs. They also work fine when the two carbs are bolted to the engine as long as the carb that has the throttle cable connected to it isn't bolted tight to the engine. When I tighten it up the cable starts sticking. I've unhooked the linkage bar between the two carbs and it still sticks. I've looked numerous times and can't find anything that is hitting the carbs that would cause this issue. Don't know if I'm missing a gasket between the engine and the carbs and it is hitting the little brass oil injector stem. It has one thin paper/ cardboard gasket between the carb and the engine.
It only sticks if the carb is bolted tight against the engine, if it is a little lose it works fine. Any suggestions would be appreciated, I've removed the carbs and reinstalled them at least 12 times trying to get this working.
