ok so this has been an ongoing problem with my seadoo xp.. last year i took the ski out once it ran perfect but took a little bit of water do to an un knoiwn leak... the next time i took it out it would not go up to full throttle.... so i took it to the dealer and they got it working so that there was just a minor hesitation in the throttle... the very next time i took it out after testing it from the dealer i was back to where i started... this year i decided that rather than mess with the carbs again i would gamble and buy a used pre cleaned set... i also change all the fuel lines, emptied out the fuel tank and removed it and cleaned it so it was immaculate.. so i got them they looked great and it turns out they ran great as well. the ski ran the best it has ever ran for the entire hour i took it out. then two days later when i went to take it out again it went right up to half throttle from the dock.. then it dropped right down to next to nothing.. it would only idle and when i went to give it gad it would just bog and not go up... but then every so often it would catch and take right off for a couple seconds.. then right back down to nothing...
i need help! i'm all out of ideas lol
the last things i think it could possible be are a ground wire of some sort that may be loose or corroded (obviously a far fetched idea)
the fact that i am running premixed fuel
maybe inline fuel filter... but i doubt it because the fuel should be immaculate due to the fact that there is nothing in the tank..
and thats all i got.. any one with any ideas!!??!?!?!?!? thanks in advance!
