Hello, Im new to this forum but I will try and do the best I can to describe my problem. I have a 1996 Seadoo 720GS that has just recently gotten back from getting everything fixed at a local mechanic shop. The guy who was doing the work has had a shop for the past 20 years and had good reviews from friends and other customers and got my ski running well. I picked it up from the shop running, took it home, parked it overnight until around 12 noon the next day when suddenly from outside I hear my ski starting by itself without the DESS key and idling all on its own. I decided to unbolt the negative wire off the battery until I had time address the problem. I tried figuring out the problem but every time I connect the negative wire the motor would turn over regardless if it had the key on it or not. My mechanic claimed to have put a new MPEM in the ski and had it programmed with the key. I would get 2 beeps with it before and after this problem occurred(I would try putting the key on while the ski was turning over by itself and it would give me 2 beeps) I have bought a new solenoid, tested the start/stop switch, traced the grounds to make sure they were good(only know of 1 that is on the motor) checked the stater to see any wires out or metal shavings at the bottom, and the ski also has a new wiring harness. I had an electrician see if he could find the problem and he traced it back to the MPEM. Usually I would've taken it back to the mechanic but he had just gotten into a really bad motorcycle accident so that option was out the window. Appreciate any help!
