I have a 93 GTX. I'm new to jetski mechanics, but am very familiar with mechanics and motorcycles. I just bought this ride and got it running. Compression is 125-126 both cylinders. no oil leaks, fresh gas. Motor runs/idles great. Throttles up great (don't have tach so no RPM reading). Test in water....idle speed up to 1/4 throttle is fine, seems to have good propulsion, anything over that and it sounds like a slipping clutch(on a motorcycle). lots of engine power, not much forward movement. Looking at the water behind the machine I see that it is clear until i pass the 1/4 mark, then get highly airated (bubbly). Any suggestions on what this could be? I have checked the jet blades nothing that looks bad to me and the clearance between the rubber ring look tight, I need to get some feeler guages on it to see what it actually is. Air must be getting into the jet from somewhere?
Thanks,
Doug
Thanks,
Doug
