RENEDUCE Member May 26, 2021 #1 I'm having a little issue with Cavitation a seen a post about putting a zip tie on the carbon seal bellow, does anyone have a picture of where to place the zip tie?
P POPPS Well-Known Member May 27, 2021 #2 It would appear that your carbon ring is not sealing, it is not the accordian bellow,,,you need to remove the "c" circlip BEFORE you pull the pump.
Digdog Active Member May 27, 2021 #4 Cavitation can also come from worn impeller and or wear ring and too much clearance between the two.
