Hi guys,
I’m having a very hard time removing a rusted out supporting ring from the jetski.
I purchased it as a non running jetski and I got it up and running but is taking water due to a carbon seal that needs to be replaced.
I have all the parts but I can’t remove the supporting ring that makes contact with the carbon seal.
I tried PB blaster, I can access the ring with a pipe wrench (I stuffed a cylinder with synthetic rope) so the shaft does not move but I can’t free up the ring.
I used leverage to try to slide the ring towards the carbon seal but no luck.
I cut the rubber boot that holds the carbon seal to get better access to it.
Wondering if any of you encountered this issue before and how were you able to free it up.
I’m almost to the point of cutting off the shaft.
Any help will be highly appreciated
