Why my sea doo gti 130 2009 dont have a oxygen sensor?
hawker
Hi!
My sea doo is diferente of others!
They dont have oxygen sensor and the fuel pressure is just 2bar!
I have use etanol, and the engine works so better and powerfull!
and why the trottle body open more than 90º?
wait
thanks
The throttle body can be adjusted. Once you get past 90 degrees you are decreasing the air flow which will decrease engine RPM's.
2 Bar is 29 PSI. Not sure what it should be,,, just put the number out there for others..
so, why the torttle comes oginaly with more than 90º?
I adjust for 90º, i need to go back to original? (maybe 95º?)
how this ecu engine read the mixture without oxygen sensor?
Soon i will post photos and videos of my GTi works with etanol!
wait
Are you getting confuse? It should be 90 degrees and 100 percent. How do you know its 90 degrees? did you measure with a protractor or are you looking at computer data at 100 percent?
its a 90 defrees! Before i adjust, th trottle open 95 degrees!
